» Newsletter?
Yesterday at 11:08 pm by Tarty
» Raphia in 15mm
Yesterday at 2:12 pm by Zippee
» Disordering Terrain Effect
Thu Feb 15, 2018 10:19 am by Jim Webster
» Quick Reference Sheet
Wed Feb 14, 2018 4:01 am by Daschuk
» Doubt on '+'
Tue Feb 13, 2018 3:21 pm by Zippee
» Melee Modifier for Charging Stationary Chariots
Thu Feb 08, 2018 10:10 am by Zippee
» Opportunity Charge Questions
Wed Feb 07, 2018 3:22 pm by Cyrus The Adequate
» Extra Combat Dice for better Quality Troops?
Wed Feb 07, 2018 1:05 pm by Gaius Cassius
Vapnartak. Sunday 4th February 2018 Knavesmere Stand York Racecourse
Thu Jan 04, 2018 7:54 am by Cyrus The Adequate
Hi Gents
York is the usual first event in the UK Impetus calendar. This year …
Comments: 28
BI2 tournament - 12 May 2018
Tue Jan 23, 2018 10:26 am by RogerC
Following the success of the Battle of Evesham, I thought I’d do another …
Comments: 4
I've brought the confirmed details for the Basic Impetus competition to the …
Comments: 32
February 2018
Help in making a errata/FAQ
Go down
Post by dadiepiombo on Tue Jun 20, 2017 11:05 am
It would be helpful to collect in a single thread all those things (in the English edition) that you think need to be put in the errata/FAQ file.
Re: Help in making a errata/FAQ
Post by Tarty on Sat Jun 24, 2017 12:47 am
5.7.1 Voluntary Interpenetration
The 5 points under 4) only apply to S,T,FL and CL ?
This was asked in our game last night and caused some confusion.
Post by wombatdazzler on Sat Jun 24, 2017 9:56 pm
A few things we spotted:
Add the Impetus is only for charging units into the English test.
P14 the Retreat/Pursuit Table - Retreat is misspelt Retrat
P45 List 23.5 Early Swiss - No unit is listed as containing the General - We assume any FL
P55 List 32.8 Italian Minor States Dates are wrong - 1494-1429 AD - Should end with 1529 AD
cheers
Daz
wombatdazzler
Post by dadiepiombo on Tue Jun 27, 2017 3:58 pm
@ Tarty. Yes they apply to those troops
@ wombrbatdazzler. Yes FL. Only with VBU 5 or 6.
Post by wombatdazzler on Wed Jun 28, 2017 7:56 am
Large Unit Bonus
If the front rank is Pike, Spear, Halberd etc and the back rank is T. Does the unit get a large unit bonus?
wombatdazzler
Post by Tarty on Sun Jul 02, 2017 12:19 am
7.6 Melee Procedure
Modifiers For Melee
+1 for the Unit including the General
This is not on the Quick Reference Sheet
Post by dadiepiombo on Mon Jul 03, 2017 8:32 am
@wombatdazzler
No bonus, The bosnus is kust for unit formed eneterly with that weapon.
@ Tarty. Ok. The QRS will be regularly updated with the last corrections and can be downloaded as pdf. There is another issue on movement.
Post by Aurelius on Wed Jul 12, 2017 11:07 am
Sling range factors v mounted. Not sure if this is intended or is a typo, The shooting factors table shows Slings verses mounted as the same at Short and Long range.
TD
Aurelius
Post by Aurelius on Wed Jul 12, 2017 11:18 am
List 2.2 Athens.
Compared with the other Greek lists the Athenians seem to be missing a skirmisher. The basic list provides 9 bases and includes just 1xS. While Thebes for example provides 10 bases including 2xS. Not a big issue but Athens looks to have been short changed!
TD
Aurelius
Post by dadiepiombo on Sat Jul 15, 2017 7:36 am
sling is ok. It has been improved as really effective.
As for lists, well with 340 some choices maybe are questionable. Athens can deploy a Cl, Thebes not. As far as possible I tried not to make them too similar.
Post by Roundie on Sun Jul 16, 2017 7:46 pm
List 1.17
is option 1 correct?
change 1xCM + 2xFL for 1xCGL
Roundie
View user profile http://miniatureaddiction.info/
Post by Tarty on Mon Jul 17, 2017 2:41 am
Roundie wrote:List 1.17
Just had a look at this. Yes I'd say that's right your exchanging 3VD for 3VD .....or 3x very mediocre units for one good one Wink I can attest to this just took NKE in a competition on the weekend those 6/3 CGL's + various are very handy indeed Cool
Post by Tarty on Mon Jul 17, 2017 2:49 am
7.6 Melee Procedure
Modifiers For Melee
+1 if in melee after attacking on flank or rear
This +1 needs to be added to the QRS under Melee 'Other Tactical Modifiers'
The +2 that's on the QRS now is only for first contact.
Post by jorneto on Mon Jul 17, 2017 11:55 am
Actually, it is FP and not FL.
jorneto
Post by Tarty on Tue Aug 01, 2017 12:44 am
6.5 Pilum and Point Blank Weapons
Only get to use these once per game - just needs to be clarified.
Post by prapor on Wed Sep 20, 2017 6:13 pm
List 7.3 Early Germans
There are FL and FP Warriors in list, and they can form Large Units. No words "same type". Can we form LU FP+FL?
prapor
Post by wombatdazzler on Sat Sep 30, 2017 7:29 am
Do Generals give a plus 1 in combat?
I think this is covered by 2.6 that says Generals give an advantage to Initiative and Cohesion.
Is there something I have missed?
Cheers
Daz
wombatdazzler
Post by qprfan99 on Wed Oct 04, 2017 2:30 am
Army List 1.13
Could you clarify Option 1 please (I am very much a newbie & also a newbie to Ancients).
The first part "changing Chariots with Chariots" is fine but the next line just says Cavalry etc
And then it jumps to Option 3
Thx
Larry
qprfan99
Post by bunwin63 on Tue Oct 17, 2017 11:03 am
Is there a contradiction between 5.2 and 5.21?
5.2: "..the unit can wheel (first) and move (afterwards) for the rest of the move"
5.21 [Chariots]: "...it is the only unit that can wheel and move"
bunwin63
Post by RogerC on Tue Oct 17, 2017 1:11 pm
Bunwin, isn’t 5.2.1 simply the exception to 5.2? So chariots move normally, except they can move at leat 1H then wheel without being disordered. All other units which start undisordered can move and then wheel, but are then disordered. I suppose 5.2 could say that there is an exception for chariots, but is that needed when 5.2.1 follows immediately? Or are you saying that 5.2.1 needs to be clarified to say that chariots are the only units which can move/wheel ‘without being disordered’? For me, it is sufficiently clear when 5.2 and 5.2.1 are read together.
I note in passing that 5.2.1 could be a bit misleading when it says chariots are the only unit which ‘can wheel and move’, since they must move before they can wheel. Again, though, I think the intention is clear.
RogerC
RogerC
Post by bunwin63 on Tue Oct 17, 2017 8:12 pm
Not clear to me at all I'm afraid. To me 5.2 says units can wheel then move, and 5.21 says chariots can move then wheel. To me its clear that chariots can't wheel then move. But then the 2nd last sentence of 5.21 contradicts that. 5.2 says that every unit can move and wheel, so why does 5.21 say that only chariots can move and wheel?
Oh well, thousands play BI and understand 5.2, so I'm clearly the exception. I'll mark my copy to change 5.21 to say "it is the only unit that can move and wheel"
thanks for answering
Bryan
bunwin63
Post by RogerC on Tue Oct 17, 2017 9:23 pm
Hi Bryan. I agree that 5.2.1 is misleading when it says chariots can wheel and move, as they must move before they can wheel. The word order in the rule is wrong. On the other hand, 5.2 discusses when other units can wheel then move. For me, it is the question of disorder which is key. Chariots can move then wheel without being disordered. Other units (which are not disordered) can wheel then move, but if they do so they are then disordered.
You are not alone in struggling with some of the wording in BI2. It took me ages, and lots of help from others, to understand the interpenetration rules in 5.7.1. In that case, and in your case of 5.2 and 5.2.1, knowing ‘full’ Impetus doesn’t provide the answer.
RogerC
RogerC
Post by bunwin63 on Wed Oct 18, 2017 6:43 am
"The word order in the rule is wrong"
So it seems. Might be a language problem
thanks
bunwin63
Post by prapor on Mon Dec 11, 2017 9:07 pm
Sorry about this old question, but tactical modifier +2 contacting an enemy on the flank o rear applies only on first turn, or in case of draw in next turns too?
prapor
Post by dadiepiombo on Thu Dec 28, 2017 10:20 am
it applies also in the next rounds of melee
Back to top
