» Raphia in 15mm
Today at 1:34 pm by Zippee
» Newsletter?
Yesterday at 4:38 pm by Tankred
» First Game Of BI2
Yesterday at 4:36 pm by Tankred
» Disordering Terrain Effect
Thu Feb 15, 2018 10:19 am by Jim Webster
» Quick Reference Sheet
Wed Feb 14, 2018 4:01 am by Daschuk
» Doubt on '+'
Tue Feb 13, 2018 3:21 pm by Zippee
» Melee Modifier for Charging Stationary Chariots
Thu Feb 08, 2018 10:10 am by Zippee
» Opportunity Charge Questions
Wed Feb 07, 2018 3:22 pm by Cyrus The Adequate
Vapnartak. Sunday 4th February 2018 Knavesmere Stand York Racecourse
Thu Jan 04, 2018 7:54 am by Cyrus The Adequate
Hi Gents
York is the usual first event in the UK Impetus calendar. This year …
Comments: 28
BI2 tournament - 12 May 2018
Tue Jan 23, 2018 10:26 am by RogerC
Following the success of the Battle of Evesham, I thought I’d do another …
Comments: 4
I've brought the confirmed details for the Basic Impetus competition to the …
Comments: 32
February 2018
Extra Combat Dice for better Quality Troops?
Go down
Post by Eques on Tue Feb 06, 2018 12:26 pm
Was this really necessary or just pointless tinkering?  Quality I thought related to a unit's organisational skills, not its grit in combat.
This is why I am always trepidous when I hear that a ruleset is going to be revised.
Eques
Re: Extra Combat Dice for better Quality Troops?
Post by Gaius Cassius on Tue Feb 06, 2018 5:13 pm
Actually, I like the change a lot. One die extra doesn't sound like much but added with the flank supports it means that VBU4 T or FL units meleeing against C class troops can get 6 to 7 dice in a melee. That means they stand a much better chance of hitting and potentially winning combats against impetuous FL and CP. In the past they just got wiped out. Now they have a small but reasonable chance to win.
Impetus has been revised consistently over the past 5+ years that I have been playing it. Most of the changes introduced were ones that I didn't originally like but I have slowly come to appreciate most of them.
Gaius Cassius
Post by Tankred on Wed Feb 07, 2018 9:29 am
The last 4 games I used that rule and I was quite satisfied. Fist, when playing with flank support, there is a need to give expensive troop an melee advantage too, since they get outnumbered by cheaper troops. I think the combination works and you need to consider both bonuses in one thought.
The games speed up a little bit with these extra dice and usually this works for both sides. So that is also appreciated.
Tankred
Post by Eques on Wed Feb 07, 2018 10:09 am
Gaius Cassius wrote:Actually, I like the change a lot. One die extra doesn't sound like much but added with the flank supports it means that VBU4 T or FL units meleeing against C class troops can get 6 to 7 dice in a melee. That means they stand a much better chance of hitting and potentially winning combats against impetuous FL and CP. In the past they just got wiped out. Now they have a small but reasonable chance to win.
But I don't think Missile troops or skirmishers should be defeating melee troops. They didn't in real life. Under the previous rules they still had a chance to damage or disorder the opposing unit, but to actually defeat it is a stretch.
Eques
Post by Eques on Wed Feb 07, 2018 10:13 am
I've always thought this modern trend for "speeding up melees" is overrated, tbh.
I like a mechanism that reflects the push, shove, ebb and flow of ancient battles.
Eques
Post by Gaius Cassius on Wed Feb 07, 2018 1:05 pm
Eques wrote: But I don't think Missile troops or skirmishers should be defeating melee troops.  They didn't in real life.  Under the previous rules they still had a chance to damage or disorder the opposing unit, but to actually defeat it is a stretch.
Depends on what you are imagining occurring in melee. I don't always think that melee means units come into direct contact with the enemy. In the case of melee troops fighting missile troops a win for the latter might represent the ability of the missile troops to put up a large enough volume of fire to keep the melee troops from closing. That is how I imagine a unit of Peltasts defeating an warband in combat. When infantry melees against CL I am not imagining that the CL are ever necessarily contacted in real life. Should a CL take a hit in the game it could represent part of the unit deciding simply to ride away under pressure for good.
Gaius Cassius
Back to top
