» Raphia in 15mm
Today at 7:35 am by Frostie
» Newsletter?
Fri Feb 16, 2018 8:15 pm by jeztodd
» Disordering Terrain Effect
Thu Feb 15, 2018 10:19 am by Jim Webster
» Quick Reference Sheet
Wed Feb 14, 2018 4:01 am by Daschuk
» Doubt on '+'
Tue Feb 13, 2018 3:21 pm by Zippee
» Melee Modifier for Charging Stationary Chariots
Thu Feb 08, 2018 10:10 am by Zippee
» Opportunity Charge Questions
Wed Feb 07, 2018 3:22 pm by Cyrus The Adequate
» Extra Combat Dice for better Quality Troops?
Wed Feb 07, 2018 1:05 pm by Gaius Cassius
Vapnartak. Sunday 4th February 2018 Knavesmere Stand York Racecourse
Thu Jan 04, 2018 7:54 am by Cyrus The Adequate
Hi Gents
York is the usual first event in the UK Impetus calendar. This year …
Comments: 28
BI2 tournament - 12 May 2018
Tue Jan 23, 2018 10:26 am by RogerC
Following the success of the Battle of Evesham, I thought I’d do another …
Comments: 4
I've brought the confirmed details for the Basic Impetus competition to the …
Comments: 32
February 2018
Using Impetus for TYW
Go down
Post by Gaius Cassius on Mon Dec 28, 2015 5:55 am
I know that Lorenzo is planning to publish Baroque in the near future but I have been thinking lately about how Impetus could be modified to include Thirty Years War armies. My inspiration has been reading about a new set of rules called Tercio by a couple of gamers from Spain. Tercio certainly shows influence from Impetus. What I like about Tercio is that they keep the same frontage as Impetus (12cm for 28mm.) The more I read the more I have become convinced that TYW is really an extension of warfare the shows much in common with the tactics and practices of the later Italian Wars. Impetus should be able to handle this. I've been toying with the idea of integrated one stand units of pike and shot.
I'd be interested if anyone has done some tinkering of Impetus with respect to late 16th and early 17th century armies.
Gaius Cassius
Re: Using Impetus for TYW
Post by Granicus Gaugamela on Mon Dec 28, 2015 8:41 am
Modifying the Large Unit rule to cover the Tercio and Group move and fire is about all that's needed to get a playable game.
Others may want more flavour, bu tthat should give you the ability to make a Tercio work as well as the later linear firepower that ultimately led to their decline in the TYW.
Granicus Gaugamela
VBU 4
VBU 4
Post by dadiepiombo on Wed Dec 30, 2015 8:01 am
Making Baroque I realized how things had to be changed. Well many things changed for Baroque will work also for Impetus 2 (the reactions), but the tactics of this later period is a bit different and some specific adjustment has been required. But yes, most of the philosophy is the same. Probably Baroque will fit cery easily to the next period (the XVIII Cent.)
Post by jeztodd on Sat Jan 09, 2016 9:58 pm
I have played French Wars of Religion using Impetus and just had to make some rules to cover the large Reiter pistol shooting cavalry. In this game still had the Pike as FP units and the shot as T shooters.
Cheers Jez
jeztodd
Post by Jim Webster on Sun Jan 10, 2016 4:22 pm
Baroque is going to be good. Very Happy
In fact I think that it might feed back into Impetus 2
Post by Gaius Cassius on Sun Jan 10, 2016 6:37 pm
Hey Jim I agree. But from what I know about Baroque the level of the unit in Baroque is the brigade and not the regiment. So Baroque functions at one level higher than Impetus. Personally I think Impetus, as it stands, operates at a scale that works very well for TYW and ECW (one unit equals about 500 infantrymen.)
Gaius Cassius
Post by Tarty on Wed Jan 13, 2016 8:11 am
Quiet a few new troop types to be added to play TYW but yes I get your drift Gaius battlefields are not that far removed from each other. Played a few TYW games that felt very much like an ancients fight Smile
Post by dadiepiombo on Thu Jan 14, 2016 9:36 pm
Actually Baroque and Impetus have the same (non)scale. It is because in a standard game you can field 4-5 foot "Units"
Post by Gaius Cassius on Fri Jan 15, 2016 4:38 am
But why the shift to 18cm frontage for infantry units?
Gaius Cassius
Post by dadiepiombo on Wed Jan 20, 2016 10:40 am
mostly for basing compatibilities. But Baroque they are just suggested base, as you can use any basing (if both armies are based the same)
Post by Jim Webster on Thu Jan 21, 2016 6:31 pm
Also because movement is based on BU, you can tweak the speed of movement to match the base sizes
Back to top
