» Basic Impetus Army List - French Wars of Religion
Yesterday at 4:15 pm by jeztodd
» Parthian Army List
Mon Mar 19, 2018 3:04 pm by Jim Webster
» Late Romans vs Goths
Sat Mar 17, 2018 12:46 am by Cyrus
» Blemmyes - an enquiry
Fri Mar 09, 2018 2:26 pm by Jim Webster
» Latest Army
Wed Mar 07, 2018 8:43 pm by Tarty
» Shield re-roll version 2
Wed Mar 07, 2018 9:18 am by Aurelius
» Help/ input on connection problems wanted
Tue Mar 06, 2018 6:45 pm by Greymouse
» Condottieri supplement
Fri Mar 02, 2018 6:28 pm by dadiepiombo
» Updated Pictish Army List
Tue Feb 27, 2018 11:39 pm by Brighouse
Vapnartak. Sunday 4th February 2018 Knavesmere Stand York Racecourse
Thu Jan 04, 2018 7:54 am by Cyrus The Adequate
Hi Gents
York is the usual first event in the UK Impetus calendar. This year …
Comments: 28
BI2 tournament - 12 May 2018
Tue Jan 23, 2018 10:26 am by RogerC
Following the success of the Battle of Evesham, I thought I’d do another …
Comments: 4
I've brought the confirmed details for the Basic Impetus competition to the …
Comments: 32
March 2018
Does a little bit of terrain block shooting
Go down
Post by Sun of York on Mon Jul 25, 2016 11:37 am
Final question from today's game. Needs a picture to explain and the best I can do is this:
Imagine the light cavalry unit 6 cm to the rear and that it wants to fire on the foot directly to its front. There will be a little bit of wood in the way. Will this block the shot?
Sun of York
Re: Does a little bit of terrain block shooting
Post by Gaius Cassius on Tue Jul 26, 2016 2:13 am
The LOS rules and the related firing issues is something that I hope is better explained in Impetus 2.  In simple terms, LOS itself is determined by "measuring from the middle of the sighting Unit's front to the middle of one of the sides of the Unit that must be spotted." (3.1.3) The CL, if I understand your explanation is, should be able to meet that condition.
In 6.3.2 you next determine Visibility. The firing unit traces two straight and uninterrupted lines to two corners of the enemy unit. These lines may not cross each other. If there is no obstacle obstructing these lines then the target unit is visible to the firing unit. A friendly unit or even an enemy unit might obstruct direct fire. Does terrain obstruct visibility? (It definitely obstructs LOS.) Here the rules seem vague.
This is how we have interpreted the visibility rule. If a unit is firing through terrain that could impair LOS then we allow the unit to fire up to 5U with respect to visibility. So a unit having one of its tracing lines firing through a bit of woods would have a maximum range of 5U firing distance.
I am curious to see how others have worked this out.
Gaius Cassius
Post by Zippee on Tue Jul 26, 2016 5:42 pm
As GC says,
3.1.3 and 6.3.2 refer to LOS and something called Visibility and Measurement
LOS and measurement (range) are essentially the same - centre of shooting edge to centre of nearest target edge.
"Visibility" (6.3.2) is to do with arc, defining a fire zone and that zone being blocked by "obstacles" - principally friendly units, hence the reference to indirect fire.
Reading further into 3.1.3 however we discover (amongst other things) that woods reduces the LOS to 5u, it only blocks it beyond this distance.
I think in the situation illustrated the CL would be partly in the woods, but within 5u of the edge thus eligible to shoot - 3.1.3 is categorical on this.
So as you can shoot through woods if within 5u of the edge it seems logical that woods therefore do not block visibility (6.3.2) within that distance, otherwise the rules wouldn't be vague they'd be contradictory.
Essentially I agree with GC - it would be nice if 6.3.2 didn't introduce the term 'obstacles' without definition but I think we can safely define it as something that blocks LOS and all units.
Back to top
